Hello there, i am new to the forum and also to op amps.
Currently i am building an FM transmitter that uses 4046 as PLL, LB3500 as n-divider and TC9122P. I am using 4046 PC II to drive the VCO. I'm currently moving on from using passive RC filter to filter the PLL output and now using op amps as active filter as the 4046 datasheet suggests. I've build one and it kinda worked. The frequency is there i've checked that but i get some kind of 'distortion' from the filter which overmodulate the VCO and render it unusable thus the frequncy is not locked because of that effect. I am new to op amps and trying to understand what causes that. I've attached schematic and component layout. UVCO is the output from 4046.
I've tried to fix the problem by changing C22 to 47uF and it worked to remove the 'distortion' effect but the frequency is not locked yet. But when i attach 470R in series with 47uf in any points before the non inv input of the second CA3240 it removed the unwanted effect and the PLL is able to lock indicated by an led, but the locking process becomes slow. My RC filter lock time is comparably faster. Currently i'm monitoring the RF, lock condition etc using cheap SDR and SDR++ as i am waiting for my oscilloscope, spec analyzer etc to arrive. I also used MPXTool.
