Display for 3D printer
Discussion in 'General Electronics Chat' started by Screen0, Dec 2, 2017.
  1. Screen0
    Dec 2, 2017
    I'm working on stereolithography 3D printer that will use LCD panel. I won't go into details about how it works (google SLA LCD 3D printer). The important point is, that I need near UV-passing LCD. I'm talking about 460nm wavelength. I'll remove the backlight and install my own high power UV LEDs. Another requirement (although less important) is low viewing angle. The display should be as small as possible (ideally less than 10") and have resolution 1920x1080 or higher. In the worst case, the resolution could only be HD, but this directly affects the resolution of the printer, so the higher, the better. Price shall be lower than 400 USD.
    I'm a complete beginner when it comes to displays. I don't know if it's better to buy the panel and controller separately or together as a kit. I've found out, that LVDS interface is easiest to work with, as there are many controller boards and even more displays supporting it. But kits are dumb-proof and I don't want to debug one component for months. I've composed a short list of potential displays, but I have no idea about their UV-passing property. Do you know better screens and controllers? Could you help me to select the correct one? I appreciate any help.
    LIST:
    Kit 1: https://www.aliexpress.com/item/10-...DLP-projector-LCD-and-driver/32796452369.html
    Kit 2: https://www.aliexpress.com/item/256...t-Glass-Virtual-Reality-HDMI/32794379549.html
    Display 1: http://www.panelook.com/LTL106HL01-001_Samsung_10.6_LCM_overview_20690.html
    Display 2: http://www.panelook.com/TX18D200VM0EAA_KOE_7.0_LCM_overview_19990.html
    LVDS Controller 1: http://www.lcdparts.net/MS531LC.aspx
    LVDS Controller 2: https://www.ebay.com/itm/HDMI-DVI-V...624120?hash=item19df01deb8:g:1~sAAOxyrUZRymfp
    PS: I apologize for any grammar mistakes. I'm not a native speaker.
    Cheers,
    Adam
