discharge capacitor with a light bulb
killivolt
Joined Jan 10, 2010
836
Please DO NOT touch a conductor (the insulator should be ok if it is rated for the voltage) that is being used to discharge a capacitor.
I think at this point, since he works on them regularly a cheap discharger would be sufficient to use on a continued bases.
Just purchase it. Then you can watch the pretty light dissipate while being assured it's not charged when the light dies slowly.
kv
tbb2
Joined Jun 27, 2014
14
Am I correct in understanding I can connect a 120v 60w bulb to a 440VAC capacitor and a the bulb voltage rating does not apply? Is the only consequence that a 120v bulb will burn out sooner or would the filament actually blow quickly not allowing the capacitor to discharge?
Deleted member 115935
Joined Dec 31, 1969
Just a on the side thought
finding a light bulb with a filament might be a bit difficult, they are becoming less common,
Ian0
Joined Aug 7, 2020
13,317
I would favour a resistor over a lamp. Filament lamps have a "cold" resistance which is only a tenth of its "running" value, so even a small 230V lamp will take a large inrush current.
I suggest repurposing a couple of old multimeter probes, removing the plugs at the meter end, attaching the resistor and sleeving it. Then you have a device for discharging 300V capacitors safely.
I used to think that all power-factor correction capacitors had a built-in bleed resistor. I found out the hard way that that was not the case. It was even more of a surprise as the equipment was not connected to any supply at the time. It was 200uF.
