Fixed V surplus computer power supplies are basically throwaways and most of recent vintage do not have published schematics since they were not designed or expected to be repaired.Did the kit come with a schematic?
So you know that the problem isn't the input voltage so to solve the problem you remove the known working part and replace it with a different one??OK, you could be right. The RD6006 display indicates that the input voltage is up to par, i.e., 24 volts being delivered by the power source. So I will try connecting a different source.
59 volts coming out the front would be a lot more than I am likely to need, ever, so I would be glad just to get enough to deliver 17 furshlugginer watts.The only real problem with less than 60 volts on the input is that the output will only go up to a maximum of (Vin - 1)Volt
Sorry, I thought I had answered that. No. It won't go over 9V with no load. 9 volts max. What does that tell you?So you know that the problem isn't the input voltage so to solve the problem you remove the known working part and replace it with a different one??
Third time of asking: does it go over 9V with no load?
Hope that Pedant Engineer isn't reading this thread.When we first tried to uses an SMPS supply for (BLDC) the spindle motor of a 5-1/4" hard drive (ca. 1980) we noticed that when trying to spin up the motor, the supply voltage would drop to it's knees and not bother to stop there. The problem was exceedingly poor transient response.
It came as a kit. Some will include a schematic with expected voltages to help newbies troubleshoot an assembly problem.Fixed V surplus computer power supplies are basically throwaways and most of recent vintage do not have published schematics since they were not designed or expected to be repaired.
It tells me that it isn't just because you have some random piece of nichrome connected.Sorry, I thought I had answered that. No. It won't go over 9V with no load. 9 volts max. What does that tell you?
The "kit" for it is the Panel device and a bare chassis/box to hold everything. You have to supply the surplus computer fixed voltage switch-mode power supply to go into the chassis. It doesn't even include a power cord.It came as a kit.
He can read anything he wants. At least I was able to learn from other's mistakes and be part of the solution. In those days I was the "firmware" guy, and it was tweaking the startup procedure that was the initial solution, but better loop dynamics was the ultimate solution.Hope that Pedant Engineer isn't reading this thread.
There was one step that I skipped, and that may be part of the trouble. The Youtube segments all show the assembler checking the input from the power source to and from the switch and the mains receptacle, then from the source to the connector at the back of the control panel. So I will include that step when I replace the fixed-voltage supply.It tells me that it isn't just because you have some random piece of nichrome connected.
The input voltage is OK, the output voltage is not. Therefore the problem is with the bit between the input and the output.
There is no way for me to decide whether it is a faulty part or faulty construction. Maybe with a schematic and some measured voltages we might get somewhere. Otherwise I would just be guessing.
If it didn't come with a schematic, draw one and post it. We can help you troubleshoot.It could be defective or the results of my own error, but I don't know enough to troubleshoot it.
Draw a schematic of the control panel? I can draw schematics, but this device is two or three layers of boards, including a processor and a display, and it isn't really a PS, it's a buck convertor crammed into a pretty small space. Besides, I got it working right.If it didn't come with a schematic, draw one and post it. We can help you troubleshoot.
What was the problem?Besides, I got it working right.
I got it. The trouble may have been of my own making, or it may have been in the previous enclosed PS, but I took the whole thing back to square one, yanked the original enclosed PS, put everything back together with a different PS with roughly identical output, tested the connections between mains and PS and between PS and control panel. There was 24 vdc going from PS to control panel, so that was up to spec. I added a ground between the PS and the case, checked the connections I might have crossed up previously, and tried it again. I re-read the how-to instructions and punched in 20volts to the "V-set" display. It worked. I took it up to 22volts. That worked, on the display and according to my multimeter. I haven't tried it on the nichrome heater, but this is further than I got before. When I check out the previous enclosed PS I'll report the results.Did it at least have a wiring/connection diagram? The PSU is typically AC on one end and DC on the other. Some of the computer PSUs have to have a load connected to have an output. Test the PSU outputs with a meter and post.
I wish I knew definitely. I just did it about an hour ago, and I haven't had time to go over the now-removed enclosed PS to see if that was the source of trouble. I will carefully put that all back together and see what it delivers. IF that one works up to spec, then the problem was in either my assembly or in my clumsy attempt at setting the control panel. In my opinion, both the PDF user guide and the RD6006 videos available give short shrift to the operating procedure. For a newcomer, the 2-minute-21-second video of setting and using the controls goes by pretty darn fast. It's like one of those speeded-up nuts & bolts sections from a YouTube assembly video.What was the problem?
| E | Multimeter wrong results | Technical Repair | 16 |
| Similar threads |
