AlbertHall
- Joined Jun 4, 2014
- 12,663
Does this thermometer have a fine enough focus for the wire to completely fill its field of view?I'm using an infrared thermometer. The wire gets up to maybe 230º.
Mr. Hall, thanks for including that example in your post. That gives me a place to start in learning more about Ohm's law.No.
The values being numerically equal is a consequence of the nichrome being 1 Ohm. Had it been 2 ohms then you would get 12V at 6A.
Go study and understand ohms law.
No.I've seen the same wire doing its job, up to about 350ºF, and it is not grey at that temperature.
| Thread starter | Similar threads | Forum | Replies | Date |
| E | Multimeter wrong results | Technical Repair | 16 |
| Similar threads |
