I have Mylek tower fan. It has a timer option to turn off after a period of time, this is quite useful to have it turn off at bedtime when I have hopefully fallen asleep. Unfortunately it beeps very loudly when it turns off, which is a pretty stupid design! It wakes me up when it does this which defeats the object of having it on before I go to sleep.
Looking at the PCB the beeper is mounted behind an LCD screen and that is glued to the PCB has well as many delicate pins so I don't fancy removing it to get at the beeper. On the solder side I've tested bridging the two solder points together (highlighed in the photo below) with a paperclip and this disables the beeper.
My question is if I permanently solder these two points together is this going to cause a problem?
