direction of current in parallel
wongburger
Joined Sep 10, 2012
4
i have two diagrams (for the same circuit) one has only two arrows denoting the direction of current flow, and the second has all of them, as well as labels on some of the resistors showing the positive and negative end. my question is :
How do i determine which way current will flow through different parts of a given circuit?
below are the two diagrams:
http://cl.ly/image/3s3f2n1y3U0m
http://cl.ly/image/1L3a0A2F322Z (this is the one with arrows to show direction of flow)
ive looked through the chapters in my book and searched online but articles titles "direction of flow" all seem to relate to conventional current vs electron flow
help would be much appreciated
35,154
You don't worry which direction current flows. Stick with one direction and work out equations using Kirchoff's Laws. It is common to use clockwise direction for loop currents.
If you get a negative answer then the direction is reversed.
wongburger
Joined Sep 10, 2012
4
can i use the same method for kirchhoff's voltage law to determine whether the voltage increases or decreases at a given resistor?
basically just make assumptions and then correct their signs later?
in the figures i posted previously, when using the voltage law on the lower left loop, (going CCW, starting above the voltage source) i know i would first +100V and then +60V because the resistor is connected to the VS in series, then subtract Vg because the drawing shows its positive and negative terminals, but do i add or subtract the voltage associated with the 5Ohm resistor?
