Direct vs indirect current measurement
ebeowulf17
Joined Aug 12, 2014
3,307
I've seen a lot of threads recently in which someone asks for advice on measuring current with a meter - often it's someone who doesn't realize that you must change your probe/meter connections and that you must also interrupt the circuit you intend to test. Quite often an experienced member here starts by telling them that you don't need to measure current directly, because you can just measure voltage across a resistor of a known value.
While I understand the concept, and it certainly is easier and more direct to do it that way in some cases, it seems like there are also plenty of cases where it would be much simpler and/or more accurate to use the meter's current setting.
If there's a circuit that doesn't run all of its current through a known resistance, then there's no way to measure voltage across a resistor to find current, unless you break the circuit and insert your own sense resistor. If you're at the point of breaking the circuit, why not just use your meter's current setting at that point?
Here's a schematic for a circuit I made recently (with a lot of help here) to switch an output and limit the total current on that output in order to protect the circuit in case of a shorted wire on the output:IMG_3742.PNG
In order to test the short circuit protection/ current limiting, I used my meter's current setting and shorted the output to ground (the load resistor in the schematic was a dummy load for simulation, not present in the real circuit.)
At first I was going to show this schematic as an example of a circuit you'd have to use an external sense resistor for, but I finally realized that R6 would give you a really close approximation of output current (it would also include LED current.) Even with the R6 idea, if you haven't already measured the actual resistance of R6 before building a circuit around it, your voltage to current calculations after measuring R6 voltage will be somewhat loose.
Kind of rambled here, but here's my real question. Is there a reason so many people seem to really dislike using a meter's current setting? Seems to me like whatever is most convenient for any given circuit makes sense, but that's not the impression I get on these forums.
Reloadron
Joined Jan 15, 2015
7,954
My best guess is simply because unlike a voltage measurement using the meter to measure current involves placing the meter in series with the load, not always convenient. That's all I got. :)
Ron
WBahn
Joined Mar 31, 2012
33,251
Switching back and forth between current and voltage modes on most meters runs the risk of making a voltage measurement when in a current-measuring configuration and blowing your meter (or at least your fuse) and possibly damaging the circuit or perhaps even worse. The fact that it becomes an ever-present risk means that it almost certainly WILL bite you from time to time.
IF you can identify a suitable resistor in the circuit, then you can make your current measurement will very little impact on the circuit while doing so. Voltage measurement, in general, cause negligible disturbance to the vast majority of circuits, especially today's meters. Current measurements are much more likely to influence the measurement than most people realize (particularly newbies). Even when you stick a current-sense resistor into the circuit, you are in a much better position to choose an appropriate resistor to minimize the impact -- most people (even experienced folks) will not take the time to ask what the burden resistance of their current meter even is, they'll just stick it in the circuit and assume the number it reads is correct.
dl324
Joined Mar 30, 2015
18,476
My Simpson 467 states that the burden voltage on the 200uA scale is 0.25V max. It's actually 0.2V nominally because the shunt resistance is 1000 ohms.
Measuring voltage causes less circuit perturbance because input impedance is 10M.
When analog meters were more common than digital, we all knew the sensitivity of our meters (in ohms per volt).
