Dipole Antenna diagram
drc_567
Joined Dec 29, 2008
1,156
... It was several years ago .... One of the better sun spot cycles ... I operated a HW-101 on 20 meters ... A roof top dipole. My conception of the di-pole 'mechanics' was rudimentary at best.
BR-549
Joined Sep 22, 2013
4,928
I don't believe a dipole works that way. I look at it as an EM field transducer/converter. I believe it converts angular fields to linear fields and visa-versa. I think it acts like a sling. It swings an arc.....then releases it straight out. This sling can catch too.......and it swings an arc as it catches a straight field.
I'll bet if we could paint an EM wave........slow it down........and watch it go by.........we all would be surprised.
joeyd999
Joined Jun 6, 2011
6,519
In fact, I was surprised by the color green. I was thinking more like chartreuse, myself. A green E-field? Seriously?
drc_567
Joined Dec 29, 2008
1,156
@BR-549
I think you may be correct about the E-field orientation. It is not as depicted in the diagram. As the electron current traverses the wire from center to end, the E-field would be radially directed, going outwards, and the magnetic field would be circumferential in nature, about the wire.
Maybe the diagram is just suggesting the relative magnitude of the E-field. It is misleading though.
... Thanks for pointing that out ...
