Hello all,
I've got what seems to be a fairly simple question regarding linear voltage regulators, I'm just not sure if my logic is correct. According to the image shown, the efficiency of the regulator would be approximately 42%, which is pretty bad. The regulator shown (MIC2954) is capable of producing 5V with anything up to about 30V, but the efficiency is obviously even worse.
My questions are these:
1. Is it possible to use diodes to drop the input voltage enough to improve the efficiency of the regulators, and is that even practical?
2. What are the things to consider if this approach is taken?
I know it's probably better to use a switching regulator, but they're costly and require quite a few more external components (I know, so does stringing together diodes ). Any thoughts or alternate approaches?
