Hi ,can any one tell whether the diode is a passive or active component
What, in your words, marks the difference between a passive and an active component?Hi ,can any one tell whether the diode is a passive or active component
There are a few different, and somewhat conflicting, definitions of active and passive electronic components out there, which is one (and just one) of the reasons I asked the OP to explain what her understanding of the difference was.
If the definition is just that they control the flow of electrons through them, then would photodiodes or light-dependent resistors be considered active devices?
The distinction that I original learned was that an active device has the ability to increase the power content of the signal while a passive device does not. Using that definition, a diode would not be an active device.
The Wikipedia article on Electronic Components (http://en.wikipedia.org/wiki/Electronic_component#Active_components) seems consistent with this, but then proceeds to list all diodes as active components (but gives no justification for doing so).
I'm actually not positive about a truly hard definition and I suspect that for any definition someone could find a device that falls into a gray area, so it is once again important that the context of the question be taken into account.
What exactly "control the flow of electrons"?What i am thinking is ...if it is about the change in the amount of electrons flowing then the passive component resistor also oppose the flow.Can you please explain in detail about this....
If you charge a battery you have increased the energy in the battery. Does this violate the law of the conservation of energy? Of course not. All we have done is taken energy from one place (the coal at the power plant or the gasoline in your car) and put it someplace else (the battery). The same with an active device (say an amplifier). It takes energy from one place (the power supply) and puts it into the signal.As you said active device increases the power....increasing power indicates creating energy but this is not possible according to law of conservation of energy.....
Shortcircuit diode troubleshooting | Test & Measurement | 10 | |
Fuse + Diode for input protection | Power Electronics | 8 | |
| T | best way to avoid diode drop? | General Electronics Chat | 11 | |
TVS diode vs ESD suppressor | Power Electronics | 10 | |
Schottky diode with low leakage current | General Electronics Chat | 8 |
