Hi folks,
Just a stupid question ,how can I find out what spec of a diode is on a old pcb board? Thanks a lot
Thanks, do you know how I can find out the spec of it? I’m trying to find a compatible one to replace itThe Red one is a Zener diode, the Blue ones could be Shotkley diodes or Ultrafast diodes.
There’s only 2 dots and a strip on it.Read the letters/numbers on them.
Thanks a lot, I’ll try to take it off and measure. Do you have any idea of the zener diode? It looks like burnt and it’s hard to see the number and letter on it. I can see a C and 6.Do you know what their function is in the circuit?
You could take a guess and assume they are general purpose silicon diodes.
You could take one out and measure it. By measuring the forward voltage drop you can tell between standard diodes and Schottkey. Standard diodes will have a drop of about 0.7V, Schottkey about 0.2-0.4V at small currents (10 - 100mA).
The thing you can't measure (easily) is their reverse voltage breakdown rating. Unless they are zeners which are possible to measure. Best to investigate the circuit to get a rough idea on that. If standard diode you could replace with the 1N4000 range. The part number varies with breakdown voltage. Go high if not sure.
Does that apply to the zener as well?There’s only 2 dots and a strip on it.
Get a schematic for the circuit. If one doesn't exist, trace the board and make one. Once you determine how they're connected, you can see what specs they need to have.Just a stupid question ,how can I find out what spec of a diode is on a old pcb board?
Yea I found the zd but couldn’t find the value of itLook at the ident on the PCB.
If ZD<number> then its a zener.
If D<number> then its a normal diode.
Thanks I don’t really know the function, I’m new in electronics stuff. Just did some simple circuit back in uni. Trying to learn bit by bitDo you know what their function is in the circuit?
Thx Marley,Do you know what their function is in the circuit?
Likewise here.Looks like blue, red, brown, gold to me. 620 ohms, 5%.
You can read the voltage rating on the nearby large capacitors and get some clue about the reverse voltage specification of the black diodes. For the zene diode you can use a DC power supply and a medium value resistor to find it's zener voltage. BUT using salvaged diodes, especially those with very short leads, such as these, is not the best choice in most instances. The heat and mechanical stress of removing them can cause compromised performance.Get a schematic for the circuit. If one doesn't exist, trace the board and make one. Once you determine how they're connected, you can see what specs they need to have.
Diodes from the first post:
Zener diodes will have a part number printed on them. You're going to have to remove it if you can't make out the important markings. When I install them in a board, I bend the leads so the important information will be readable.
