Diode Forward Bias characteristics
logearav
Joined Aug 19, 2011
243
Revered members,
Kindly see my attachment.
From the options given, i think the answer is ON switch, because when the input is low, that is when the applied voltage is below the breakdown voltage(0.7 V for Silicon) the current is low and when the applied voltage is equal or above the breakdown voltage, there is saturation.
Am I correct?
Adjuster
Joined Dec 26, 2010
2,148
Note however that the term "breakdown voltage" is also commonly used to denote the reverse breakdown voltage at which a diode begins to conduct, i.e. the limit of its reverse blocking capacity. http://en.wikipedia.org/wiki/Breakdown_voltage
I believe that technical English (at least in UK), normally refers to the "forward voltage" or "cut-in voltage" for conduction in the preferred direction.
logearav
Joined Aug 19, 2011
243
Adjuster,
I stand corrected. It is forward voltage ( 0.7V for Si and 0.3V for Germanium). Thanks for clarifying.
