One way to visualize this (though it is getting harder for students to relate to today) is to think of the diode as representing a "cathode ray tube". The vertical line is the "cathode plate" and the triangle represents the spray of cathode rays coming off the cathode, starting at the center and spreading out. Since we know that "cathode rays" are actually electrons, that means that the "spray" is actually electrons, and thus the "arrow", which is pointing in the other direction, is in the direction of conventional current flow.
This little device is useful in general for keeping the concepts of "anode" and "cathode" straight.
Which is why it is getting harder for students to relate to today.This is all assuming your students know what a CRT is.Yes we still have them ins scopes but how soon will they disappear entirely?
Right. The plusatrons know exactly when to jump off the phosphor and run to the cathode.If you always think of conventional current flow you will never have a problem relating to electronic circuits.
I can think in both, but I suspect if you come across a tube circuit you think in terms of electron flow, no?I must be an exception. I came through the vacuum tube/valve era and conventional current flow works for me.
so if i comprehend, is the Franklin assumption of the electron flow fromUnfortunately the standard check valve symbol used for a diode, is based on Ben Franklin's assumption that electron flow was from +ve to -ve.
I can live with that. Conventional flow makes the math easier with the positive on the top of the page and not having to deal with all those "-" signs. It's intuitive compared to electron flow.I must be an exception. I came through the vacuum tube/valve era and conventional current flow works for me.
What drives me crazy is students at the uni who have access to the school's digital scopes, and they have no idea how to adjust them manually. Everyone just hit's that stupid "auto-scale" button and wonders why it doesn't work when the trigger is off. I always try to encourage them to adjust the knobs by hand and change the scales to make it look the way they want it to. I can't stand it when students insist on using the auto-scale button instead of learning how the scopes actually work.Which is why it is getting harder for students to relate to today.
It's the, "point and click" generation.I can't stand it when students insist on using the auto-scale button instead of learning how the scopes actually work.
Pretty much standard thinking and this method is known as the conventional flow.so if i comprehend, is the Franklin assumption of the electron flow from
+ve to -ve the standard used every where in circuit/electric diagrams ?
Don't need to.I can think in both, but I suspect if you come across a tube circuit you think in terms of electron flow, no?
I thought I covered that in post #9. The plusatrons know exactly when and where to jump off the CRT phosphor and run to the cathode. In mere amplifier tubes, they swarm around the plate, often getting too eager and causing secondary emission when they get excited about waiting for their turn to jump to the cathode.How does one figure out how to apply a negative bias to the grid? I raise the potential of the cathode by adding a resistor from cathode to ground.
Where do electrons come into the picture?
OR, you teach them that the arrow looks like a letter "A", for "Anode".... Since we know that "cathode rays" are actually electrons, that means that the "spray" is actually electrons, and thus the "arrow", which is pointing in the other direction, is in the direction of conventional current flow.
