Dragan733,..... parallel to G-S of the mosfet. With ....
Yes, yes. I had to say: D-SDragan733,
Did you mean to say D-S which is drain to source rather than G-S which I would take to mean gate to source?
hgmjr
Sorry to ask about diode function as well.What is the general application of diode beside using as a rectifier?Yes, yes. I had to say: D-S
In a signal with two polarities, through the diode always passes the signal with one polarity, + or - dependently of the orientation of the diode to the input signal.Sorry to ask about diode function as well.What is the general application of diode beside using as a rectifier?
Sorry I actually wanted to know the general function of diode.Example to protect the relay coil during power switching off.In a signal with two polarities, through the diode always passes the signal with one polarity, + or - dependently of the orientation of the diode to the input signal.
You don't protect the relay coil with the diode. You protect the transistor, C - E, during power switching OFF, when one appears negative voltages to the transistor collector . As the inductance of the relay is bigger, and the resistance of the coil relay is smaller, these negative voltages are bigger.Sorry I actually wanted to know the general function of diode.Example to protect the relay coil during power switching off.
Thanks for the info.You don't protect the relay coil with the diode. You protect the transistor, C - E, during power switching OFF, when one appears negative voltages to the transistor collector . As the inductance of the relay is bigger, and the resistance of the coil relay is smaller, these negative voltages are bigger.
The diode will be placed in parallel with the relay coil, with the cathode to + supply voltage.
BTW, the transitor in this kind of circuit is a switch or a amplifier or something else?You don't protect the relay coil with the diode. You protect the transistor, C - E, during power switching OFF, when one appears negative voltages to the transistor collector . As the inductance of the relay is bigger, and the resistance of the coil relay is smaller, these negative voltages are bigger.
http://www.wam.umd.edu/~toh/ElectroSim/relay.htmlThanks for the info.
Can you kindly let me know two to three more of this kind of example so that I can know more about electronic.Thanks.
Switch. You will read more in the links above mentionedBTW, the transitor in this kind of circuit is a switch or a amplifier or something else?
