digital starter design
Atish260188
Joined Apr 9, 2023
46
for the digital starter dersign using nuvoton microcontroller, using t type relay, transformerless supply and for 7 segment dispay for live voltage and current display, I have prepared bock diagram. so kindly check and suggest whether any modification is required or not for its best performance
Atish260188
Joined Apr 9, 2023
46
also, mcu Nuvoton N76E003 Microcontroller will serve this purpose or any better nuvoton microcontroller for the same purpose????
Alec_t
Joined Sep 17, 2013
15,117
Why are you sensing/measuring the mains voltage? If the mains fails then your micro loses its supply and won't be able to measure, control or display anything.
Is this a school/college assignment?
What is the starter intended to start? Certain loads might require sophisticated safety features.
Atish260188
Joined Apr 9, 2023
46
what about nuvoton microcontroller part number???? N76E003 would be ok or any other better nuvoton microcontroller????
Alec_t
Joined Sep 17, 2013
15,117
MS51FB9AE Nuvoton MCU this would be useful for this project?
See post #9.
