Hello all,
I try to replace a mechanical potentiometer 10k with a digital, i use the intersil X9511 (https://jp.intersil.com/content/dam/Intersil/documents/x951/x9511.pdf)
the typical circuit from the Data Sheet it is very simple but i was not work for me. I want to ask if i miss something here, i use the typical circuit with ase store pin used in autostore mode (figure 2). When i use a multimeter to measure resistance in the Vw and Vl or Vh the resistance is about 8-9K, when i try to change the output resistance with a tact switch between PD or PU with ground nothing change and after a while the resistance rise up to 100K and nothing change after that. I think i am doing somthing wrong here..
