Digital Potentiometer - Isolated/Common Ground Query
Cyclicz
Joined Apr 17, 2017
62
Hello!
I'm currently building a circuit using an 8-pin DIP Digital Potentiometer (AD5171) and controlling it with an Arduino. I was wondering if these digital potentiometers have (in a general sense) an "Isolated ground". If I end up running my Arduino controlling an AD5171 on an isolated ground loop will it still work? I'm sure it will but there's always the possibility that it won't. If the ground is "Isolated" do I connect pin 6 of the AD5171 to the logic ground?
DickCappels
Joined Aug 21, 2008
10,662
I don't have any experience with this chip but it looks like your circuit would work but (as you suspect) you need to make sure that all three connections to the "pot" are kept between GND and Vdd, otherwise something could be damaged on the chip.
To wit:
(Part of table removed for clarity)
That means that in your circuit VA should connected to ground.
By the way did you notice that this part is OTP (One Time Programmable)? Once you write a value to it you cannot change the value.
You might prefer the AD5227
Sensacell
Joined Jun 19, 2012
3,787
No- bad idea.
The Pot "resistor" is not isolated, and must be operated strictly within it's specified voltage range.
If you are trying to dim an LED, there are many better ways.
Motanache
Joined Mar 2, 2015
652
The solution with IC is elegant.
As an idea I used something simpler - A photoreistor coupled with a light bulb or LED.
Edit: Typo corrected -dc
Cyclicz
Joined Apr 17, 2017
62
To wit:
Thank you for the helpful insight. I appreciate the pointer on OTP and I'll use your AD5227 reccomendation instead.
No- bad idea.
And yes, this would be one of the absolute worst ways to dim an LED (and definitley not efficient), I had myself a chuckle. I had just used the LED as an example load.
I have no further questions.
Thanks again, everyone!
