Digital Potentiometer Help!
vinit1973
Joined Mar 24, 2011
1
I have a fully working vibratory feeder circuit wherein the electromagnet is energized to magnetize it. I use PWM for controlling the frequency of vibration and LM317 for controlling the amplitude. Both frequency and amplitude are currently varied using mechanical potentiometers. The circuit works perfectly well tillhere.
I now want to be able to adjust the frequency and amplitude using Up/Down pushbuttons. Can somehow suggest the simplest way to do so? I want the simplest way of doing it! I also want to display the settings on a small LCD screen so that the user can remember the frequency and amplitude settings for future use - though however the displayed information may have nothing to do with the actually frequency/amplitude. It may just show values from 0 to 64 (for a 64 step pot or whatever) for both frequency and amplitude.
Hope I've been able to explain my requirement!
I'll be obliged if some of you experts could help me!!!
Looking forward to your help!
Vinit Verma
SgtWookie
Joined Jul 17, 2007
22,230
Digital pots usually want to "see" only 5v between the "ends" of the "wiper", and have fairly high values of resistance. An LM317 requires a minimum of 10mA load to guarantee output regulation. That may be difficult to accomplish with a digital pot.
An LCD display would be rather complex to drive with anything other than a microcontroller, and the uC would require programming. 7-segment LED displays might be used with discrete CMOS IC components, but the project would require a number of ICs and other discreet components (a number of resistors, for example) for an R-2R ladder.
