DİGİTAL LOGİC DESİGN
RAİDEN38
Joined May 30, 2020
6
Question: Design a 7-segment displayed BCD counter using positive edge-triggered flip-flops which counts from “your student id number” to it’s “9’s complement value”, then returns to your id number again, and repeats counting sequence with the applied clock signal. Describe your design steps. Simulate your circuit using trial version of the simulation software Logicly (https://logic.ly/) or with Logisim (https://sourceforge.net/projects/circuit/). Save and upload the simulation file you designed (please check it works!) with your exam report.
MY ID = 17290240
JohnInTX
Joined Jun 26, 2012
4,712
Welcome to AAC!
For help with homework problems, please show your work so far and we can help you with the details. We do not do your work for you.
dl324
Joined Mar 30, 2015
15,511
I really work a lot but at this question ı am stuck ı am not figure out.
Post your work so we can see where you're getting stuck.
What flip flops are you using?
I saw an earlier post that had a PDF attachment. I couldn't download because the thread was deleted or moved.
RBR1317
Joined Nov 13, 2010
706
Is this project to be designed around "your {particular} student number" or is the project supposed to accept a student number that is entered manually? Does the circuit need to compute the 9's complement or will you find the 9's complement before designing the circuit?
Also, does it need to be a sequential counter, or can it be a parallel counter where each digit counts up to its final value individually?
Papabravo
Joined Feb 24, 2006
19,852
Let's start real simple: how many flip-flops will be required to show 8 decimal digits. If that question is too challenging, then how may flip-flops will be required to display one decimal digit?
BobTPH
Joined Jun 5, 2013
6,302
Well, the first step is not to draw the schematic. Perhaps you should try to break th problem down into pieces that you can design.
Bob
ericgibbs
Joined Jan 29, 2010
17,168
hi 38,
That document is only the Final Exam question.
Where is your attempt at drawing the required circuit diagram?
We can then help you.
E
RAİDEN38
Joined May 30, 2020
6
hi 38,
E
it is a lab questions
