I have a AB PLC that requires a input of 24v for my equipment to stay running. Its getting it return +24v from the sensor. This sensor we replaced with Mechanical that goes to ground when it sees no oil psi. I added a +24v ice cube relay and wired it N.C. When the sensor faults, it goes to ground, grounding the relay, which opens up the Contacts and kills the equipment. It works as intended but it is not fail safe. Meaning, if relay failed contacts would stay close and would not shut down in a faulted condition. I can't change the Digital Input to shutdown on low (0v) input. That would have been too easy. Anyhow, I need help coming up with something to make it fail safe.
