Digital Clock with an alarm
Bruce Wayne 007
Joined Jan 24, 2019
Hello everyone..I'm designing a digital clock using 7490 ic, 7447 ic and seven segment displays..I've completed the seconds and minutes portion...This clock is to be built in a 12 hr format....I couldn't figure out how to display 1 after 12 because it resets to zero...I have to display 1 after 12 and not 0. So, how do I do this? Hope you got the question...Also, I'm thinking of adding an alarm facility too..Any ideas regarding this?
sghioto
Joined Dec 31, 2017
8,634
Before trying to fix the problem on the reset, I would re-evaluate the component values R1,R2 and C2 on the 555 clock circuit. C2 is especially large at 1000uf. Better choice is C2 10uf , R1 50K pot and 47K for R2.
SG
ericgibbs
Joined Jan 29, 2010
21,439
hi absf,
Thanks for the feedback on the 74LS192, just tried a LTS sim with a 74HCT192, also getting divide by 6.??
I will look later ,see if I can work out the problem.
E
