Good day to all. I have a Carbon pile battery load tester and the problem is that it reads amperage all the time even with everything basically disconnected. I have it down to running on my benchtop power supply with just the bare necessities to light it up and it still displays an amperage with everything else disconnected. It generally uses an inductive pickup. Not sure where to start but suspect MAX138 may be problem. I have reflowed the board suspeecting broken solder joints but no change. Thoughts on where to look and why? Here are some pics and the MAX138 datasheet.
