Different ways to extend the range of rf waves in a low power module
puzzle
Joined Oct 30, 2016
53
I have a RF module (cc1120) which is transmitting on a frequency of 434Mhz. The signal received in another RF module, 1 km far away. The problem is that the dbm of the received signal is sometimes too low (-108dbm). I am wondering what can I do to extend the signal range & strength. Note that the mcu on the board is a low power mcu and saving the battery is very important for me.
I would be glad to hear different idies in order to solve this problem.
AlbertHall
Joined Jun 4, 2014
12,663
If the transmitter and receiver are in fixed locations then you could use directional aerials to direct more of the available power in the required direction.
Put the aerials outside so the building materials do not get in the way.
Make sure you have 'line of sight' between the aerials so the signals can travel unhindered between them - for instance by raising them higher.
These measures will make best use of the available power.
puzzle
Joined Oct 30, 2016
53
By "aerial", do you mean something like :
https://goo.gl/images/13uSWT
? Can you guide me which type of aerial to buy ?
What about putting a repeater in the middle of the distance ?
AlbertHall
Joined Jun 4, 2014
12,663
What would be a problem ? The low bandwidth ? Can you please reccomend me on such aerial ?
To be clearer, any aerial intended for 433MHz will work perfectly well at 434MHz.
I do not feel qualified to recommend an aerial. I do not have experience of comparing aerials.
theamber
Joined Jun 13, 2008
325
The problem with buying antennas is that the data given is not real and that their testing is done poorly so the data given is bad. Most antennas are usually made for a wide range of frequencies unless is a very specialized expensive antenna from a reputable company, so I suggest you to make your own or tune modify one cheap one and test its gain, freq. and return loss with a network analyzer in the far field but then you are getting into a very complex subject that will take years to master.
Networks Analyzers and calibration kits used to be extremely expensive and most professional ones still are but there are companies that make decent ones for lower freq. at a cheap price like the DG8SAQ from SDR kits.
