Hello again!
I stated a new project...version 2.0...16 step 4017 seq...and took it slow...so i began soldering TLC555 (x<1hz<y) clock for sequencer.
On my breadboard all run as i intended...but the same layout on "prototype pcb" gives completely different results.
On breadboard all seems to go stable and balanced. On pcb though...things are unstable...the sound is modulating a bit...like it slightly changes pitch every second "pop"...i cant adjust the freq much..not as much as on breadboard...the difference between the freq change is significant between them.
I soldered everything in place. I triple checked everything. Then i desolder the components...put them on breadboard...and everything was fine!! Then i solder them on pcb again...still nothing changed...big difference. Does it have anything to do with the breadboard capacitance??
this is the prototype pcb
http://image.dhgate.com/0x0/f2/albu/g1/M00/83/D9/rBVaGVWd3EeAAgdyAAPFYlElwlU245.jpg
