Hi all,
I have a doubt regarding the result of h12 from following example:
which is is taken from here.
The example shown is based on the hybrid parameters matrix (wikipedia link).
Now, I tried to determine the value for h12 starting from this circuit:
The circuit equation I write is:
V_2\left( \frac{ \frac{1}{sC_2} }{\frac{1}{sC_2} + (\frac{1}{sC_1} \parallel R_1)} \right ) - \left( \frac{g_mV_1 R_2}{R_2 + \frac{1}{sC_2} + \left (\frac{1}{sC_1} \parallel R_1 \right )} \right )\left(\frac{1}{sC_1} \parallel R_1 \right ) = V_1
which solved for
h_{12} = \frac{V_1}{V_2}
does not results the same as the h12 parameter obtained from the book linked.
So the question is: what's wrong in my reasoning ? I am a little bit confused
Thank you in advance
thumb2
which solved for
thumb2
