Difference between 330 (33pF) and 331 (330pF) capacitor markings
StephenDJ
Joined May 31, 2008
58
This may look confusing, but the one on the right is marked 330 as if the zero should not be included in the value of the cap, right? If the zero means 33 x (10 to the power of zero), then there should not be 330 pF, but 33pF, correct?
jpanhalt
Joined Jan 18, 2008
11,087
I agree. When it will make a difference, check -- not unlike confirming the fuel in your airplane. Standards change, and you can never be absolutely certain whether something is labeled according to the most current standard.
John
StephenDJ
Joined May 31, 2008
58
I have a lot of capacitors around here that are marked 330 that are actually 330pF. That is why I own one of these:
aade.com
Thanks everyone. I was sorting my parts bin, and came across these. So are you telling me what I have in my bin may actually be 330pF? I have no way to check them. Just wanted to make sure they wind up in the right cabinet drawer.
33,182
You have lots of ways to check them, depending on what you have available. Do you have an oscilloscope? If so, then make a little RC circuit using 1MΩ resistors and measure the time constant. If you have some basic digital parts then you can make any number of oscillator circuits that go into a frequency divider with enough stages to blink an LED as a slow enough rate for you to visually tell the difference between 1Hz and 10Hz, for example.
33,182
John
There's a current standard for capacitor marking? :D
StephenDJ
Joined May 31, 2008
58
Good idea. Yes, I have a 20Mhz oscilloscope. Since I'm just now getting started back on electronics and getting my workbence in order, I may check this later. But I think I could use t=RC at which V=70% of peek to confirm this value. Or I could do it by reactance measurements using X=1/(2piFC).
RichardO
Joined May 4, 2013
2,270
It seems that if the value has a tolerance then the value is in picofarads (no multiplier digit). If not then the value is digit,digit,multiplier (also in picofarads).
Rant: I hate cap markings.
