Diamond fibers and Thermal conductivity
Wendy
Joined Mar 24, 2008
23,816
I wonder if diamond fiber (similar to optical fibers) can made? Diamond is the best known thermal conductor, If a fiber is created and used in a stranded cable, cound it be used to conduct unwanted waste heat away from a hot source? Something like a car engine for example.
Wendy
Joined Mar 24, 2008
23,816
I'm thinking of eliminating chilled water systems. I don't even know if diamond fiber is feasible, we can synthesize it maybe it is possible. One strong cable.
A clear case of putting mouth in gear before researching all the facts if you were to fill a car with heat pipes all merging with one heat pipe going to a radiator which is nothing but heat pipes could you eliminate water pumps?
ZCochran98
Joined Jul 24, 2018
356
Graphene and carbon nanotubes (CNTs) reportedly have comparable (and, in some reports higher) thermal conductivity to diamond (in-plane graphene/CNTs averaging 1500-2500 W/m/K, with reports up to 5300 and even 6600 W/m/K), so that's an option.
Good luck with that. Chilled water systems can use ultra-pure DI water to provide cooling and electrical isolation with a low foot-print at high-density heat targets. I'm sure it's possible to create diamond fiber but I've seen very little research on diamond based cooling systems.
https://www.epa.gov/system/files/do...at-work_Section_6.4_Chilled_Water_Systems.pdf
Wendy
Joined Mar 24, 2008
23,816
In my old job I built a lot of temperature control systems, you just made it clear how much I do not know. Thanks for the info.
Wendy
Joined Mar 24, 2008
23,816
The strength aspect of such a fiber is something I had not considered until later in this thread, it would be interesting to see how strong a cable made out of this material might be.
