buffer with "diamond" configuration
electronicsenjoyer089
Joined Feb 24, 2025
182
Hello, its me once again.
I came up with another circuit, which im trying to simulate in order to keep learning.
I made this circuit that has 4 transistors, 2 npn and 2 pnp.
What i expect from this circuit is the the input sine wave.
From what i understood the circuit below should work like this: i apply a sine wave to a npn and pnp transistors, what happens is that the transistors npn ( which is called Q1 in the schematic ) will shift down the signal by 0.7 ( this is what i see on emitter )
the same sine wave gets shifted up by the pnp transistor on its emitter ( which is called Q2 on the schematic )
At this point, the signal at the emitter of the npn transistor is given into the base of the second PNP ( which is called Q4 ), what the second pnp does it shifting it up again by 0.7 ( 0.7 is an approximation, lets say thats the drop on the diode), in this way u cancel the previous offset given by the npn, same thing work for the pair Q2 / Q3.
Now my questions are:
1)Is this the correct way to analyze this circuit? i got it well or i misunderstood? and if so then how it works?
2)Why the simulation shows that on its output, the signal goes from -4.5 to 4.5V? ( sine wave is 9V amplitude)
Thanks.
Joined Feb 24, 2025
182
Because R3/4/5 form a divide-by-two voltage divider.
ahh right... im stupid lol...
another thing, during positive cycle there is the voltage divider R4/R5 and during the negative cycle there is R3/R5?
secondly, what value should i choose to make this circuit work for the voltage divider? is like 10 ohm sufficient ( so in this way i get 9v in output )
Alec_t
Joined Sep 17, 2013
15,158
Ian0
Joined Aug 7, 2020
13,299
Yes, that’s called a “diamond buffer”.
It doesn’t need R3 and R4, you can short them out, but a value of a couple of ohms or so would stop large standing currents if your transistors are mismatched.
The circuit works better with A big capacitor between the emitters of the input pair.
SPICE generally works better if you tell it some real transistor part numbers rather than using its generic NPN and PNP.
There’s a good article here:
https://www.tubecad.com/2022/06/blog0558.htm
Alec_t
Joined Sep 17, 2013
15,158
during positive cycle the transistor Q1 is conducting and thats the path i see no?:
During both the positive and negative parts of the input voltage all four transistors are conducting. All four emitters follow the input, albeit with different DC offsets. The signal doesn't follow the path you drew in post #5, because the voltage at the bottom of R2 is clamped at -10V by the negative supply voltage.
Btw, you might want to increase R1 and R2. At the moment, the output current available from the buffer is less than the current from the signal source.
