I have a fault with my caravan heating system. The blow heating only works intermittently. Having researched online, I've found that a common issue with my system is the relays on the PCB fail.
I've removed the PCB and tested the five relays (I don't know which controls the blow heating) by putting 9v to them, and they all click; however, one of them gives me this reading when my multimeter is in continuity mode, and the relay should be open. The others all return a 1 on the multimeter. Does the high multimeter reading indicate a fault with the relay?
Thanks for your help
Matt
Matt
