Device drivers and Osi Model
Ftoso91
Joined May 8, 2018
Hello everybody,
my question is about how (peripheral) device drivers fit the OSI model. In particular:
I understand the meaning of all OSI layers when it comes to peer to peer communication (ler's say, PC to PC communication). However I get confused when it comes to communication between PC and generic peripheral device (say, the keyboard). In my understanding, here is what happens in this case (much simplified):
Let's say that one process on my PC wants to receive data form the keyboard. The process calls some Operating System routine, which invoke the keyboard function driver and any Bus driver related to the keyboard (for example, if it is a USB keyboard, the USB Host driver is invoked).
At this point, the drivers-stack manages the reading operations from the the keyboard controller (writing to its registers); then this logical chain is reversed (with interrupt or polling techniques) in order to deliver the keyboard data to the process which requested them.
This said (please correct me if I said something wrong), it is not clear to me what follows:
1) Is OSI model applicable also to (PC to peripherals) communication?
2) If yes, where are the seven OSI layers hidden within the logical process I just described?
3) Which protocols rule the OSI layers in this case?
4) Which role plays the device function driver in this scenario? Which role plays the Bus driver? Which layers do they fit?
Thank you
Federico
Papabravo
Joined Feb 24, 2006
22,106
Hello everybody,
Thank you
Federico
IMHO
1) I do not think so. More correctly I have ignored the OSI model for as long as I have been a programmer. That is 50+ years.
2) It is not there because the design imposes a layer of cruft (a highly technical term) which would make if far too inefficient for practical purposes.
3) OSI is a conceptual model. Actual implementations are based on practical considerations.
4) Buses and drivers are practical implementations that do not fit neatly in any one place.
Conclusion: Read about it, understand it, then do your implementation without it.
https://en.wikipedia.org/wiki/Cruft
Picbuster
Joined Dec 2, 2013
1,062
Hello everybody,
Thank you
Federico
In case of your keyboard the first 4 layers are applicable the rest are host layers and defined/ controlled by yr application.
layer 1: cable
2: data link act on rts when applicable
3 and 4 transmit the byte(s).
The osi as stated before is a model we all using it without realizing.
And yes we are now able to build a control on each layer allowing to detect a failing layer however this will slow down the process.
A better way is to use a polynomial checksum over the first 4 layers (transmission).
Picbuster
