Detecting water flow in a pipe
Alec_t
Joined Sep 17, 2013
15,138
I've noticed that some hall sensors stop detecting when they're exposed to magnetic fields continuously for too long... that's why I'd like it to wiggle, but I'm going to make sure and test it.
I wasn't aware Hall sensors did that. You could always put a coil around the sensor and pulse it occasionally to wake it up :).
Ian Paull
Joined Oct 17, 2014
1
Well, in this case there is access to the internals of the pipe. And my question is, other than a paddle or a turbine, what else is there that I could use to detect its motion?
How about allowing a movable obstruction (like a magnetic piston) that can be pushed downstream by the flow, and that an external electromagnet can return to the starting point when you sense the travel limit has been reached?
cmartinez
Joined Jan 17, 2007
8,812
Thanks, I had already considered that. In fact, that's the technique most on-demand water heaters use, but they use a reed switch instead of a hall sensor. But there's a strange thing going on with the sensor I chose. The sensor is active low, and if it's exposed to a steady magnetic field for too long, then it will stop detecting and go back to its normal high state. So it's important that the magnetic field fluctuates. Besides, its fluctuation frequency can give a rough indication of the rate of flow.
swr999
Joined Mar 30, 2011
58
swr999
Joined Mar 30, 2011
58
^^^ If you want a rough estimate of flow rate you might try a second un-heated thermistor a bit upstream of the heated one. The delta should be proportional to flow rate.
cmartinez
Joined Jan 17, 2007
8,812
Thanks. In fact, I built a circuit exactly like the one you've described a few years ago, except that it worked with two transistors and not a thermistor. And it worked like a charm to measure the flow of air. But this application is battery-powered, so current draw is critical, and therefore this technique is off the table.
Tonyr1084
Joined Sep 24, 2015
9,744
Just chiming in on this thread, but: (first 90 seconds are the point) Beyond detecting the slightest movement, which they seem to know when I have a dripping faucet, you can later upgrade to measuring the amount of water to have passed through. Perhaps the water company might have some older models they would part with for cheap. You don't seem to care about accuracy, so - - - .
ebeowulf17
Joined Aug 12, 2014
3,307
What sensor are you using? I've never experienced that behavior with any of the hall effect sensors I've worked with. It reminds me of the way capacitive touch sensor circuits are often designed to be self-calibrating constantly, meaning they can only be used for intermittent signals that are mostly off.
If I were in your shoes, I'd be shopping for a different sensor that behaves normally. For all the time and effort you're putting into this project, you shouldn't be limited by the behavior of one quirky sensor. If the sensor does exactly what you want, that's great; but if it's preventing you from using methods that would otherwise be viable (and it sounds like it is,) I think you should seriously consider scrapping it.
cmartinez
Joined Jan 17, 2007
8,812
Thanks for the suggestion. The sensor I'm using is the SM351LT, and the reason I chose it is because it works at an extremely low power, in the order of 360 nA. And the glitch itself does not affect the function I want it to perform, since the presence of flow means that the sensor will be constantly switching on and off anyway. It doesn't matter which state it's at when at rest.
Per your request, I've attached its datasheet.
ebeowulf17
Joined Aug 12, 2014
3,307
Cool, thanks for the info! I forgot that you mentioned low power consumption being a top priority. That certainly narrows the options quite a bit.
I am still intrigued by the behavior you describe. Nothing in the datasheet makes it sound like it should be doing that. I'm not clear on when it goes in and out of "sleep mode," so maybe if I understood that better it would help explain the odd behavior.
Sounds like it doesn't matter for your application, but I'm just curious for my own interest now. Among other things, I'm wondering if there's some secondary effect coming into play, like a nearby piece of ferrous metal which reacts slowly to the changing magnetic fields and gradually skews the sensor reading. I love a good mystery!
cmartinez
Joined Jan 17, 2007
8,812
Maybe (and I'm just guessing here) the strange behavior manifests itself because perhaps I'm using too strong a magnet, and it's somehow saturating the sensor. I'm also sure that its internal circuit is self-calibrating somehow, and that's what's causing the anomaly.
ebeowulf17
Joined Aug 12, 2014
3,307
The sensor you are using is a magnetoresistive sensor, it is not a hall effect.
Yeah, I noticed that too, but forgot to mention it. I'm not sure if it makes much difference to the overall project since all the analog stuff is handled internally within the sensor, and it has a flip flop driven push pull output.
