Detecting water flow in a pipe
cmartinez
Joined Jan 17, 2007
8,813
How about just detecting the sound of the water flowing through the pipe !
That's a lot harder than it seems. Imagine all of the other sounds present in a domestic pipe. Besides, what does smooth running water sound like inside a pipe? The only technology similar to what you're proposing is ultrasonic sensing, which is out of the question in this application.
Alec_t
Joined Sep 17, 2013
15,143
Another possibility: hang a thin flexible plastic 'curtain' across the inside of the pipe and attach a tiny magnet to the base of the curtain. The slightest (or largest) flow should deflect curtain plus magnet in the flow direction and the magnet shift could be detected externally with a Hall effect sensor.
cmartinez
Joined Jan 17, 2007
8,813
That's a possiblity... but maybe it would be affected by the pipe's position (vertical or horizontal), which I'd like to be anything the installer chooses.
Alec_t
Joined Sep 17, 2013
15,143
If the pipe interior is at domestic mains pressure then a small pressure drop should be tolerable. You could have an interior flap valve normally held closed by light spring force. Opening a tap to demand flow would create a differential pressure enough for the flap to move against the spring force, opening the valve. Mount the magnet on the flap.
SamR
Joined Mar 19, 2019
5,515
Your paying for WiFi on that one. Doesn't really give any info on the detect method. The cheap flow measurement method is the venturi tube. Then there are differential pressure across an orifice plate, Coriolis effect, and even nuclear gamma-ray devices. Coriolis and nuclear are bot "Non-Intrusive" devices and measure from outside the pipe. Somewhere there should be a flapper valve type indicator device that when the fluid in the pipe flows the flap swings opens and pushes out an external indicator and also serves as a check valve but I'm not finding one.
cmartinez
Joined Jan 17, 2007
8,813
That sounds very interesting ... but how do I guarantee that the flap would wiggle on throughout both flow extremes? Its wiggling frequency is not important, only that it does.
Alec_t
Joined Sep 17, 2013
15,143
There's no wiggling with the post #34 suggestion. Why must it wiggle? Hall sensors can respond to static and moving magnetic fields. Can you give the reasons for your constraints?
cmartinez
Joined Jan 17, 2007
8,813
I've noticed that some hall sensors stop detecting when they're exposed to magnetic fields continuously for too long... that's why I'd like it to wiggle, but I'm going to make sure and test it.
And on the plus side, wiggling frequency could give me some very rough estimate on flow. Although I know I've already said that flow measurement is not really necessary... just trying to leave an open door here.
12,219
You sound a very arrogant person
He is not. He is a regular contributor with an excellent reputation. Note: 6K messages, over 7K likes.
The majority of the responses so far, including yours, have ignored a critical requirement in post #1:
A reasonable lower limit for flow detection would be 0.1 lt/min. That would yield a flow linear speed of approximately 1 mm/sec.
That is one inch every 25 seconds, or one foot every 5 minutes; a *very* slow linear velocity. I don't think any amount of digital signal processing could extract enough of a change in acoustic spectrum to make a *reliable* determination.
More details are in post #5:
I need to either rotate or shake a small magnet so a hall effect sensor will pick its presence. That's a design constraint and it can't be changed.
