Desperately need help designing thermocouple circuit
Wehan
Joined Oct 26, 2012
2
Hi All,
I have to design a thermocouple circuit using a K-Type thermocouple. The output should be 4-20 mA(4 mA at 25degrees Celcius and 20 mA at 40 degrees Celcius). I can just use my multimeter to measure the output current. Apparently there is a simple current follower circuit that I can build to achieve the desired 4-20 mA output, using only one thermocouple. I have been reading for a full day and decided to join this blog after realizing that the task at hand might be more complicated than I thaught,
Any advice or circuit diagrams?
Help would be much appreciated!
Wehan
Joined Oct 26, 2012
2
Thanx for replying Bill, but I have to design the circuit myself and I am not allowed to use the AD595AQ IC...
Sensacell
Joined Jun 19, 2012
3,442
Oooh ouch. your professor is a sadist?
1) read up a bit on the thermoelectric effect, this knowledge will come in real handy.
2) read the data sheets for chips that are designed for this application, this will help you to understand what the problems are, which is half way to the solution.
BillB3857
Joined Feb 28, 2009
2,570
Sorry, I didn't realize this was homework since it was posted in the Projects section. Maybe a moderator can move it to the proper section and you may get more help.
