I don't quite understand.I will try to use 12-24v and adjustable current through L297's Vref volt and bridge's sense resistor combination.
Thank you, of course you are right. Not a big problem to add a few resistors.HP1729, your suggestion will result in smoking rubble, as once the P-channel MOSFETs are turned on their is no current path to turn them back off, and when their corresponding N-channel MOSFET turns on, the current from the source will be limited only by the Rds (ON) of the MOSFETs and the sense resistor.
by Duane Benson
by Robert Keim
by Jake Hertz
by Aaron Carman
