Designing a simple alarm circuit using microcontroller
spinnaker
Joined Oct 29, 2009
7,830
ErnieM, I have started to write the code using XC8 compiler and I am stuck with the delay in flashing the LED. This is my first programming experience so please bear with me.
Why are you redefining _delay_ms?
#define _XTAL_FREQ 4000000 // Oscillator frequency for _delay()
#define _delay_ms(1000) // Remove this
That is likely one of your problems right there.
And a value of 1000 for a 4mhz clock might be too large of a value. The compiler should be complaining.
spinnaker
Joined Oct 29, 2009
7,830
I do not understand your question.
Admittedly I am not familiar with your level of chip, but I don't see you turning off the LED. I assume it is connected to GP5?
And it should be
__delay_ms(1000);
not
Surprised it compiled.
nestbulala
Joined Dec 12, 2015
111
Yes, spinnaker, the LED is not getting turn off if the alarm signal or GP0 is low. It should be turning off only when reset GP3 and GP0 is low.
Please find the attached code including delays and other buttons. It compiled successfully but I don't know if it work in microcontroller.
eetech00
Joined Jun 8, 2013
4,712
Hi
Structure your program similar to this:
// use defines to allow use of friendly names
#define Alm_in GP0
#define Ack_in GP1
#define LT_in GP2
#define RST_in GP3
#define LED_out GP5
#define ON 1
#define OFF 2
#define FLASH 3
#define LL 0
#define LH 1
// function prototype
void set_LED(int state);
int main(void) // this is read automatically at start up
TRISIO = 0b00011111; // Set GP5 as output, GP0-4 as input
while(LH) // begin infinit loop
If(RST_in == LH) // if reset is high
//do some stuff...​
} else {
MCLREN = LL; // Reset the MCU​
spinnaker
Joined Oct 29, 2009
7,830
eetech00, I tried to compile the code but I got stuck on page 84 for some unexpected syntax. Please analyze what could have been missed. I am also having problem on the else statement and the MCLREN=LL.
You need to learn to analyze yourself. This is a simple (and common) mistake that is easily found. Your editor should have a bracket pair matcher. If it does not then get an editor that does. In MPLab editor place your cursor on one bracket. The corresponding bracket will be highlighted.
if(GPIO2 == 1) // if Lamp Test is high
__delay_ms(100); // de bounce for 100 ms
{ // <<<<< Looks like extra bracket.
GPIO5 = 1; // Output to LED is high
And the error should not be "unexpected syntax" it should be "unexpected end of file". an unexpected end of file most times means an unmatched bracket.
nestbulala
Joined Dec 12, 2015
111
eetech00, some minor changes, compiled and tested in the circuit and found the following:
1) Alarm GP0 is pressed, GP5 flashes quickly. Required condition GP5 flashes one second off, one second on.
2) Alarm GP0 is released, GP5 steady lit. Required condition GP5 should remain flashing.
3) Ack GP1 is pressed, no action. Required condition GP5 should be steadily lit.
4) Lamp Test GP2 is pressed, GP5 lamp goes off. Required condition GP5 Lamp should be on.
5) MCLR GP3 is pressed, no action. Required condition should reset the CPU and GP5 should be off if Alarm GP0 is off too.
I will try to play with the timings and maybe interchanged the GP2 and GP3 if I get good results.
eetech00
Joined Jun 8, 2013
4,712
Hi
I have re-written the code to reflect the conditions described above.
Try the attached code.
EDIT: made corrections.
nestbulala
Joined Dec 12, 2015
111
eetech00, the latest changes does not work at all. The previous one main_v2 only the GP5 flashes when GP0 is pressed and off if released. It should latch and remain flashing until acknowledge have been press. Other functions like ack and lamp test reverse output.
eetech00
Joined Jun 8, 2013
4,712
Hi
It worked as expected using the MPLAB simulator to test.
Are you using the MPLAB simulator to test? or an ICD?
I don't think you are initializing the simulation correctly.
1. Start the simulator.
2. pause the simulator
3. set all I/O (input) pins to "1"
4. "reset" simulator
5. "continue" the simulator
After step 5 above, you should see GP0-3 = 1, GP5=0
If you then "fire" GP0= 0, GP5 I/O pin will alternate between 1 and 0 indicating a pulsing output state.
nestbulala
Joined Dec 12, 2015
111
I am downloading to the target and simulate it using kanda development board. I am sorry I don't know how to use the MPLAB simulator.
eetech00
Joined Jun 8, 2013
4,712
HI
I'm attaching a revised schematic. It has been revised to show the PIC connections as well as a modified relay control circuit.
The relay will de-energize (and the PIC will reset) when the reset button is pressed.
I'm also attaching modified source code. This code was compiled and tested on a PIC12F629 and operates per your requirements.
nestbulala
Joined Dec 12, 2015
111
Hi eetech00, Code was downloaded to the target and when power up, GP5 steady on, push the Alarm GP0 and it flashes, push the Ack GP1 it reset and GP5 LED is off. other buttons no action. I may have been doing the wrong way in compiling and downloading but some of my projects works by the same way. I don't know why it work for you and mine is not. That maybe you can call it experience. I may do it persistently to get my results. Will you please upload the asc file for the circuit.
