I have a home built CNC machine that i built 8 years ago, a purchased some Hall Affect Sensors, which have worked great. I was forced 3 years ago to reverse engineer the sensors see image below since one of them stopped working and the original supplier has stopped making them. i was successful in doing so now the controller board has stopped working and i need to replace it. the sensor board is normally closed not open unlike a micro switch.
i have come up with this design, that uses RJ9 connectors, Active Invertors to flip normally closed to normally open. i also wanted to include a buck convertor to step down the voltage from my power supply 25volts to 5volts, plus i wanted some additional 5v capability and finally the ability to jump sensor output together i.e. x+ and x-.
I'm looking for a way to test the circuit since I'm not an electronics engineer. I do have a Gerber file for EasyEDA software see attached.
Madaxe
![1700763774781.png 1700763774781.png](https://forum.allaboutcircuits.com/data/attachments/295/295875-276d33bf76e064ed049336de3185439a.jpg)
![1700763671073.png 1700763671073.png](https://forum.allaboutcircuits.com/data/attachments/295/295874-db3d25e10e97a0da5f6cc42a6aa5e996.jpg)
Madaxe
