Hello
I think we need to revisit the timing diagram in post #29. Are the following statements correct?
1. L854 timer is “master” timer and resets all other timers
2. Beacon time can be adjusted independently of other timers except master.
3. Floodlight time can be adjusted independently of other timers except master.
4. Obstacle “on” Time is dependent on floodlight time and master.
5. All control outputs are contiguous. That is, one output is always energized except at start or reset.
Questions:
A. What are the additional “time” dependencies ? For example, can be beacon “on” time be longer or shorter than floodlight time?
B. When should auto shutdown begin?
C. Manual shutdown can be initiated anytime after start is initiated?
D. Are you comfortable using AC relays or are DC relays (powered by a wall wart) an option?
E. Are there any failure modes that need to be avoided?
Answers to some of these questions may seem obvious but I want to avoid making assumptions.
eT
Questions:
eT
