Designing a 48V to +5.5V(2A) and -5.5V(1A) power supply
Ameet Gohil
Joined Feb 27, 2019
I can create a +5.5V witha LDO but i'm not how to go about creating a -5.5V. Can you point me to some resources to do this?
AnalogKid
Joined Aug 1, 2013
12,299
At 2 A output current, your 5.5 V LDO will dissipate 80 W. Is there a reason you don't want to use a switching buck regulator?
For the - output, consider an inverting buck-boost regulator (another type of switcher).Beyond that, your only practical option is to purchase a 48 V / 5 V DC/DC converter, one with an adjustable output.
ak
pmd34
Joined Feb 22, 2014
529
As AnalogKid says, a switching regulator is the way to go with this. Its the only real way to get a negative supply in this case (unless you have a VERY lossy virtual ground by using a potential divider.) You can get some specific switching dual supply regulators, some +, some - voltage regulators also or if you check the data sheet they often show how to get a negative supply, for example:
(This is just one I use a lot myself, and much less power than you need!) Also note that in such a case the negative rail does not actually have any regulation in it in this case.
