Design with half wave rectifier with filter capacitor
amineING
Joined Apr 8, 2020
7
I would like to have your opinion on some calculations I am doing on the unregulated output of a half-wave rectifier with filter capacitor.
The diagram is as follows:
With Vsect = sinus wave with 311 vpk (220RMS).
I would like to calculate the output voltage V1. I have calculated the transfer function with Vrect1 as input:
V1(s)/Vrect1(s) = [R3/(R1+R2+R3] * [1/ (1+sC2(R1//(R2+R3)) )]
with a pole (wp) at 159m Hz and s= jw (w=2Pi*f)
In order to have V1, I put Vrect1 = 155VRMS (half-wave rectifier output) (=Vpk/2 = 311/2).
I calculate the modulus of the whole, with the frequency f=159m Hz, I find :
V1 = Vrect1 * ||[R3/(R1+R2+R3] ||* ||[1/ (1+sC2(R1//(R2+R3)) )]||
V1 = 155 * (36.1m) * ||(0.5-0.5 i)||
V1 = 155 * (36.1m) * 0.709
V1 = 3.967 V (which corresponds to the simulation).
But the problem is Vrect1. Is it correct to take VRMS for the voltage Vrect1 (or the average value VAVG?) in this case how to calculate this average value (Vrect1 avg) knowing that the filtering capacity introduces a DC voltage of 22V (see graph above).
In short, can you tell me what calculations have to be made to obtain the value of the output voltage V1?
Attached is the voltage curve at the edge of capacitor C2 (and the current IC2):
Thanks a lot!
amineING
Joined Apr 8, 2020
7
hi amine,
Welcome to AAC.
This PDF should help with the calculations. Figure #6..
Please post your LTS asc file.
E
Thank you ericgibbs for your welcome,
I've looked at the file, but I can't find what I'm looking for. In particular, the use of a filter capacitor and a voltage divider (in fact, a low-pass filter) means that the equations in the pdf file do not apply directly.
I attach the LTspice file.
Thank you very much once again.
ericgibbs
Joined Jan 29, 2010
21,506
hi,
Downloaded your asc file, runs OK.
I would use Vrms for Vrect1, with the C22 cap open circuit,
ie: no smoothing.
Will run the sim and see what I get.
E
ericgibbs
Joined Jan 29, 2010
21,506
hi,
If you are considering the available at the 10k Load resistor, via the resistive divider chain the Vsect RMS gives a value of ~636uA and the Vsect AVG a value of ~400uA, at +4Vdc
Usable Power in the 10K is ~1.6mWatt at 4V , so the current is @400uA which indicates that the Vsect AVG is the value to use.
What is the application/purpose of the circuit?
E
amineING
Joined Apr 8, 2020
7
hi,
ok, so if we have to use the average value of Vsect then we'll use Vrect1 AVG. is there any way to estimate it? i mean, if it was a simple alternating rectifier with just a resistive load, then Vrect(AVG) = Vsect(peak)/Pi
But with the lower limit of the Vrect voltage of ~22V, this value is no longer 311/Pi.
Any suggestions? Thanks.
Amine.
ericgibbs
Joined Jan 29, 2010
21,506
If this project is to measure a known possible range of Vsect [ local mains supply] it would be feasible to use an MCU with an ADC input to monitor the V1 voltage and raise an appropriate alarm if the limits are exceeded.
I would improve the filtering at the VC2 junction to cover HF transient suppression also a 5V Zener clamp across R3.
As you are also aware, the circuit is not mains isolated.
An alternative is to use a mains step down transformer for isolation.
E
amineING
Joined Apr 8, 2020
7
hi,
The edge-limiting zener diode in R3 is a very good idea.
Yes I know this circuit is not isolated, it will be completely encapsulated and the inputs and outputs will not be accessible to the user.
I can't use MCUs or transformers because of the overall cost of the system. I have to work with simple components.
Amine.
