Design The Circuit Which Converts 3 Digit Bcd Number To Binary Using 74184
digital_msstat
Joined Apr 29, 2020
11
Hello everyone, hope you're all fine. I have a homework but I can't solve it.
Question is; design a circuit that converts 3 digit bcd number to binary using 74184.
I am using Proteus 8. The problem is that using the IC. When I run the circuit, it gives error " No model specified for U1. [U1] ". I learned to solve this. I pick the Attach Hierarchy Module but this time IC is not working. I mean in the probe side, I see gray squares that refers neither 1 nor 0. How can I solve this ?
Regards,
Thanks in advance.
35,249
Welcome to AAC!
In Homework Help, we do not do your homework for you.
Show us your work that you have attempted so far.
digital_msstat
Joined Apr 29, 2020
11
Hello, I made enable pin ground / power supply, then like I said I attached to the module. Things that I can is limited. I wonder is it chronic or not. Because I am not only one that come across with this problem.
Regards
WBahn
Joined Mar 31, 2012
33,290
Are you asking for help with the design, or with getting Proteus to work?
I think I saw a recent thread where someone commented that Proteus' ability to work with that particular IC is a known issue. I don't do Proteus, so I can't help you there.
digital_msstat
Joined Apr 29, 2020
11
I designed the circuit but IC's are not working. How can I make them active in circuit ?
( Title is a little bit confusing, sorry. I am new in here)
Regards
WBahn
Joined Mar 31, 2012
33,290
Well, let's work on the title so that you can hopefully attract the attention of people than can better assist you.
Also, don't use all caps except sparingly to emphasize points -- otherwise it is considered shouting and turns people off.
Does this sound more appropriate to your needs: "Having problems simulating 74184 circuit in Proteus 8"
dl324
Joined Mar 30, 2015
18,481
Proteus isn't free, so only members who have it will be able to give any meaningful help. Is there a Proteus help forum? Since it's a homework assignment, your instructor should be able to provide guidance.
