Design prototype for Automatic phase shift and analyse the data with wireless current transmitter
karzo94
Joined Apr 3, 2018
21
I need expert advice to design the prototype circuit which will help me to shift the phase which I am going to try on 208V at 60 Hz which is further connected with sub-panels consist of AC circuit breaker of 10 Amps.
I want to use the prototype with the Wireless current transmitter which will send the signal to the circuit and detect the power issue disturbance.
I have only worked with basic current detection circuits and this much advanced so your best advice on this will help me a lot to create this kind of solution.
38,834
Is this for power factor correction?
How will you shift the phase?
You will need to detect the voltage also, to determine the phase.
