Design of MultiStage Transistor Amplifier
Status
Not open for further replies.
MazKhan
Joined Mar 27, 2017
Hello I'm working on designing a multistage transistor amplifier with some specifications.
The specifications are as follows
1) Open circuit(no-load) voltage gain Avo = 50(+/- 10%)
2) Type of transistors is BJT
3) Maximum number of transistors is 3
4) Power Supply is +15V relative to ground
5) Output resistance can be a maximum of 15 kilohms
6) Input resistance has to be 200 or more kilohms
7) Quiescent Current drawn from the power supply can be at max 2mA
8) The Maximum no-load output signal swing can be no less than 8V peak-peak(-4V to 4V)
Can anyone give me tips on how to start designing the circuit?
JohnInTX
Joined Jun 26, 2012
4,787
The reason we ask is to see if something should be put into Homework Help. This one seems to fit here OK.
Thanks for the clarification and welcome to AAC.
ian field
Joined Oct 27, 2012
6,536
Alright, I'll get back to you after reading up on some of the tutorials. Thanks!
If you're doing a bit of searching - you might run across a very handy 3 transistor amplifier from the very early days of transistors that runs on only 1.5V. It sometimes turns up when I'm looking for something else.
All 3 transistors are direct coupled - it has to be an odd number so that a resistor from output to input provides the nfb for stable DC conditions. If you want lots of gain; use two resistors in series for nfb and connect a capacitor from the join to GND to block the AC nfb.
It should work on 15V if you scale the collector resistors. The original 1.5V version could directly drive a 600 Ohm ear piece without breaking a sweat.
ian field
Joined Oct 27, 2012
6,536
Bordodynov
Joined May 20, 2015
3,435
According to your technical requirements, I quickly developed an electronic circuit.
There are several feedbacks in it. I apologize for the delay. I was banned.
Status
