Design of Gate Driver for CMOS
Usama_ali143
Joined Jul 17, 2017
27
Hi guys ! i am in trouble and expecting a solution from www.allaboutcircuits.com experts. For your kind consideration, I have attached a picture which is enough to demonstrate my problem. kindly see the attached file. Waiting for your kind response . Thank You so much
shortbus
Joined Sep 30, 2009
10,049
In your second partial schematic, what was used? The part you cropped from the left side. There would be drive components there.
Janis59
Joined Aug 21, 2017
1,894
The solution may be very different depending do that is comparator having say 500 femtosecond speed or just most cheapest of about 1 microsecond. Anyway, irf530 in contrast of 510 may not overshoot some teen MHz barrier, at least many years ago I capitulated trying to overclock it over 28 MHz, so ANY cheap transistor booster will be just what You need. For example https://i.stack.imgur.com/ts9gi.jpg if we speak about serious FETs, or more prost for Your case as https://i.stack.imgur.com/7u33w.png.
