Hello everyone,
I have to design a DC-DC converter of an output power 15kW and it should work on 1-phase 230V to 500V as well as 3-phase 230V to 500V rectified ac.
An output power level at 1-phase 230V to 320V will be 6kW, 320V to 500V will be 9kW. Similarly, an output power level at 3-phase 230V to 320V will be 9kW & 320V to 500V will be 15kW. Which converter topology do you suggest? (output voltage of converter has to be constant throughout the supply range)
