Hi all
I would like to build my little girl a bead spinner , my background is software so I have limited electronics background.
I have some old hardware laying around that I would like to use for this project
the goal is to be able to run this motor in multiple speeds using a potentiometer.
Here is the list of items I have:
A motor i pulled from old printer (I'm pretty sure its 12v rated, tested it on 12v its working fine, not working on 9v)
I have a 12v 1500ma rated power supply
2 Potentiometers one is rated 10K the other is 50K
Bunch of different resistors (10,100,200,330,1K,2K,10K,220k?5.1K, 1M, and big 10 Ohm 2w resistors)
On off switch.
I uploaded images of the hardware here: https://imgur.com/a/MC0n3xq
Appreciate if you guys can assist designing this simple circuit.
Thank you!
On off switch.
Thank you!
