Hello Guys,
I am trying to implement a delay using timer0 interrupt. I'll just post an abstraction of the code in mikroc
The above code does not work as I expected. Can somebody please point out the mistake I am making or suggest a better way for achieving a 100 ms delay using interrupt?
C:
void inittimer()
//Timer initialization for a 32ms interrupt
void interrupt()
//interrupt code;
delayvariable++;
void main()
TRISB = 0; //PORTB is output
TRISC.F0 = 1; //PORTC Pin 0 is input and connected to a switch
if (PORTC.F0 ==0) {//check is the button is pressed
if (delayvariable==3){ //~100ms second delay to check buttton debounce
if (PORTC.F0==0) { //check if the button is still pressed
PORTB = ~PORTB; //toggle PORTB
delayvariable = 0; //reset the delay variablE
