how can i delay between the flashing of two LEDs using TMR0 interrupt
mina123
Joined Jan 1, 2023
hi everyone i kept verifying my assembly code and i still didn't get where i made a mistake,if anyone can help or guide me i would be thankful
so essentially the code must make two LEDs blinking using TMR0 interrupt routine to delay between the blinking of the two LEDs
Netwide Assembler:
       LIST   p=16f84
       INCLUDE "p16F84.inc"
       __CONFIG  _CP_OFF & _PWRTE_OFF  & _WDT_OFF
comp1         equ 0x0C
comp2         equ 0x0D
       org      0x00
       goto     start
       org     0x04
       goto    isr
isr
       clrf    TMR0
       bcf     INTCON,GIE
       bcf     INTCON,T0IF
       decfsz  comp1,1
       retfie
       bcf     PORTB,1
       bsf     PORTB,2
       decfsz  comp2,f
       retfie
       bcf     PORTB,2
       retfie
start
       movlw  0x4D
       movwf  comp1
       movlw  0xF
       movwf  comp2
       bsf    STATUS,RP0
       movlw  b'00000000'
       movwf  TRISB
       movlw  b'00000111'
       movwf  OPTION_REG
       movlw  b'10100000'
       movwf  INTCON
       bcf    STATUS,RP0
       clrf   TMR0
       bsf    PORTB,1
       bcf    PORTB,2
loop   goto   loop
       END
trebla
Joined Jun 29, 2019
599
To make LEDs repeatedly blinking at desired intervals you must reload comp1 and comp2 variables after they reached zero. For toggling output pins (for LEDs) you must check port bits state (zero or one) after desired delay and then set it to opposite state:
btfsc PORTB,1
bcf PORTB,1
bsf PORTB, 1
For additional delays use additional variables and literal constants.
