Hello all,
Here's the basic outline: I'm taking a circuit which previously had power constantly applied (it's a toy, which had batteries), and activated when the momentary switch was pressed (momentary switch isn't in-line from the power supply, it's a separate part of the circuit, connecting two pins on the circuit board). I am now attaching this to a power supply with it's own switch, which means I would like to have it activate as soon as power is applied. Holding the original switch down when the circuit is turned on doesn't work, it has to be released and then pressed again to activate it. I *believe* the proper way to resolve this is to create some sort of delay circuit so that when power is applied, there is a small delay before the original switch circuit is closed. (If someone has an alternate suggestion, I'd love to explore that as well.)
Basically:
Power on > short delay > switch circuit closed (remains closed until power off)
This is a 3v system, and I shouldn't need any long delays, it certainly feels like there should be a simple way to implement this without needing a 555 chip. I've briefly attempted to attach a capacitor to the switch circuit, but that does not seem to work. My next best guess is to do something with a transistor and a capacitor hooked to the V+ line from the power supply, so that when power is applied, the capacitor charges briefly, and then closes the switch circuit. Or possibly just a MOSFET by itself would provide enough delay?
I'm afraid I have only done incredibly simple circuits before, and trying to understand how this existing device is set up, and introduce new functionality to it is a bit beyond me.
I'm happy to take any additional readings, or I could attempt a circuit diagram if needed. I've attempted to search for other posts similar to this, and while I found many about delay circuits, they all seem to be more complicated than the delay I'm after (also, many of them just end without confirmation of success).
Basically:
