Decide between two inductors for a DC / DC converter
Glebiys
Joined Mar 11, 2019
23
I am designing a power board based on the LM2596.
Board specifications:
1) Input - 12V
2) Outpuit 5V, 2.5A
At the output, I need to put an inductor. I examined many options and settled on two:
1. TDK - 33uH, RC 3.2A, DCR 47.4 mOhm, Isat 3.2A
2. TAITEC - 33uH, RC 6A, DCR 65 - 75mOhm, Isat 8A
What prevents to determine:
1) Is TAITEC better than TDK in terms of shielding? There will be signal lines near the inductor and I would like to minimize the influence of the inductor.
2) If TAITEC has better shielding, then in comparison with TDK it has a high DCR. 47.4mOhm vs 65mOhm. As far as I understand, the lower the DCR, the better. Is 65mOhm too high?
How to be?
ci139
Joined Jul 11, 2016
2,031
it would guess the option 1 has grater "flux leakage" near "air gaps" -- but it likely takes to compute it out with some 3d grid model ...
i'm not really into this topic now
/// a while ago - i noticed while rewinding iron core transformers that using the Litz wire on secondary !likely gained a better efficiency ... likely → https://www.researchgate.net/public...s_Design_of_a_100_kHz_Inductor_with_Litz_Wire , (https://www.ieee.li/pdf/viewgraphs/fundamentals_magnetics_design.pdf)
← returned by https://www.google.com/search?q=flu...ube+bobbin+ferrite+core+inductor+flux+leakage
38,774
Can't tell for sure from the pictures.
You need to look at the data sheets.
It's a matter of efficiency.
At 2.5A, (ignoring the inductor current ripple) the TAITEC will dissipate 6.25 * 65mΩ ≈ 400mW, while the TDK will dissipate 6.25 * 47.4mΩ ≈ 300mW.
Is this 100mW difference important to the efficiency you want?
ronv
Joined Nov 12, 2008
3,770
1) Input - 12V
2) Outpuit 5V, 2.5A
How to be?
I would go with the one with the higher Isat.
Have you simulated the circuit to see peak inductor current? I always worry about that.
ci139
Joined Jul 11, 2016
2,031
there are not many occasions where the higher R.ser of the inductor can be preferred - but some of such may be ? the voltage drop at the inductor (that would otherwise draw the supply down compromising the operation of the circuit) ? to reduce ringing of the mosfet at high dv/dt (? slow down operation to enable fly-back diodes to follow up at lower voltages) ? to limit whatsoever I/O (to/from inductor) peak current (so smaller filter caps can be used) ← but this is like a last measure to consider . . . ((the high currents need to be "stored" somewhere and routed to the inductor with minimum losses))
BobTPH
Joined Jun 5, 2013
11,642
I agree with @ronv. The max current the inductor sees will be higher than the continuous output current. The first one may very well go above saturation at peak current.
Bob
